roadie1389
So the one disadvantage to the LSD is the primary hangs over far enough it will drag on the ground in a turn. Anybody come across a skid plat that works protects the rear of the primary?
Agreed never on the rigid either. Pegs should grind before the primary on the left side. I assume it's an issue with the shocks not the design. It probably grinds a little as the rear end is trailing down just happens to be the road or the angle and pressure.I've never had the primary drag on the Pit. It got scuffed from almost falling over tho... I've drug pegs and pipes on the right side....
