are the lower rocker box gaskets the same on the 117ci as a normal evo? If not I'll just order from wildsteed but if they're normal evo I'll be able to get some today. Thanks guys!!
05 BDs came with Total Performance Rocker Boxes.
They require a metal lower rocker box gasket.
If your Rocker Cover has four flush rocker cover screws then you have TPs
If you have 6 Socket Head Cap Screws around the outside edge of the rocker cover then you have S&S Rocker Boxes.
