Lost power to green starter wire
(((HELP)))
I lost the power to my green starter wire. I installed a wire plus from Jake
and it was working Great so i bundled my wires up and now it just klicks on the wire plus selenoid. Jumped the starter and it spins over fast. Battery is 12.7. What wires send the signal to power up the green wire? Can some one please help me? No power at all when i test it with the start button pushed.
THANKS!!!
Michael<><
Ray
take the bundle apart and see which one is loose. not being a smart ass but seems like the quick way
yep, yep, make sure all the connectors inside the plugs are pushed together as they should be, I had an issue with mine and that was all it was, the pin was not seated properly.
Ray
Black Rider
Mine did that and it was the ground wire to the frame. Make sure you are grounded. I tried moving mine but had to put it back and she starts like a dream.
Buster03
wire plus
(((HELP)))
THANKS!!!
Michael<><
I installed a wire plus on my bull dog but I did solder every wire into the conectors to makes sure no loose connection takes longer but well worth it I have built several bikes and this is the only way to go also make sure u left enough wire for play. Buster03:flag:
Slider
I tinned the stripped ends of the wire before I crimped them in the sockets and pins. I just liked the tight feel of it if you know what I mean.
