Kiwirider
Howdy all (in best accent)
About a month ago I was about to start my Saddle Sore 1000 ride. I had literally gassed up the bike at my start point, got my receipt and signature, took a photo, hopped on the bike to leave....... No clutch!!
It went from normal operation, to nothing just like that. I called the ride off then. I adjusted the play out to where I got pressure back. Then couldnt start the bike (another story there). Then all that slack went as well. I eventually got her running, roll clicked her into gear and rode her home.
Ok. Since then, Ive pulled the pulley side and all seemed to be in order. The push rod hadn't come loose (I was hoping it was that simple) and the cable fully adjusted out has good tension, ie hasn't broken. So Im thinking Primary side.
Ive had the clutch pack out a while back, cleaned, inspected it all and everything looked good. Ive done about 1000 miles since then. After putting it all back together clean and switching to Spectro I was pleasantly surprised at how well she shifted and found neutral.
Before I drain the oil and pull the cover. What are some possibilities that could cause a complete clutch failure with no warning?
Cheers in advance ladies and gents!!
