Loose rear turn signal
Five Five
ok like i said i wasnt sure so i pulled my lens and leds on my o4.there is not a nut on the inside only the bolt from the fender.see i can admit when im wrong:lol:my question is are we taking about a big dog or another scoot?
mobsta....is yours the 2 piece assembly (housing and foot)
Mines a 03 Pit...was 2-piece..converted to 1-piece..
bdmridgeback
Low Down Chop Shop
Won't do any good to just tighten it up, You need to loosen it up some more, put some blue loctite on it and then tighten it up. Otherwise it will just back off a couple rides down the road.
Gabriel
I will tell you that I would have been back in here to find out how to remove that led board if someone had not said to pry it out and check the nut.
That thing was stuck, I tore the gasket/seal getting it out and now need a new one if I can get just the gasket.
THUNDER
mine is loose also will tighten tommorrow, thanks for the info, I popped the lens off the other day but was in a hurry and decided to wait till had more time, and glad I did, because now I know it can be done....
mobsta
so i wasnt an idiot after all,kool,im also an ase tech.what does ase mean to me ?nothing my boss made ne get certified.:lol:
Gabriel
How many do you have?
It means a lot when that is what you do for a living, especially pay.
I'm master registered which is the European equivalent but
all those certifications are expired now and have been since I retired from the College
where I taught Automotive Technology.
mobsta
i only took what i work on.suspension and alignment.i am a specialixed tech for a very expensive car line.i used to have all of them but why bother ifi dont do everything anymore
Gabriel
It only matters if you pay is tied to it
mobsta
yup it looks good but again i been doingthe same thing now for 35years.i could probably write the test:roll::roll::roll:
