Loose rear turn signal
Gabriel
The housing is loose at the base. I have not tried to take it apart yet because to remove the mount it looks like the fender or strut will need to come off. Is this a problem? Can I reach it from the inside?
Gabriel
slip a wrench inside the fender
My question is about the two pieces that comprise the turn signal itself.
It is apparently two piece?
I was wondering if the looseness between the two pieces could be corrected without taking it completely off?
Thanks...
mobsta
yes you should be able to pull lens and leds like marv says.should be able to tighten nut on inside:)
Five Five
Thanks...
As Marv said....slip a wrench inside the fender and tighten it up....I had the same issue with mine....it worked it self loose again and I actually had to place a rubber gasket between the shoe and bucket for it not to be loose....time to time I would have to re-tighten it because it wouldn't stay tight....I finally ordered a couple new ones from Big Dog (1-piece unit) for about $21 each
Gabriel
So the bolt goes all the way through?
Gabriel
The bolt goes in from the fender...threads into the light housing.
I can tell that, but the part next to the fender is tight against the fender the outside round piece is loose (where the lens goes).
I thought it may have a separate fastener inside.
what dealer do most people use?
mobsta
have you pulled your lens and leds to look?i cant remember but i thought there was a nut on the inside of the housing
Gabriel
No not yet, i thought i would ask here first.
It might be easier to pull it apart.
I will do that tomorrow
Cobrafast1
If you examine the lens carefully, you'll notice a notch in the lens where it meets the housing. Usually, this is on the bottom and used as a drain hole for any moisture.
Just slip a screwdriver in there and twist and the lens will pop off in you hand.
The bolt on the inside of the fender can be tightened with an open end wrench. Just hold the housing on the outside of the fender at the angle you desire and tighten the nut on the inside of the fender. Simple to do.
Five Five
no there isn't a seperate fastener inside.....it appears that your inner housing is worn out like what happened to mine.....thats when i had to put a rubber gasket inside the housing to take up the slop....and eventually replaced them with the (1-piece unit)
you can order them from "Drag Specialties"
I got mine from the local "Big Dog" dealer at a cheaper price that "Drag Specialties"
mobsta
ok like i said i wasnt sure so i pulled my lens and leds on my o4.there is not a nut on the inside only the bolt from the fender.see i can admit when im wrong:lol:my question is are we taking about a big dog or another scoot?
Gabriel
It's the bike in my sig. 03 chopper
