No H2O
Planning to change oil, primary, and trans fluid soon.
Was targeting:
Royal Purple FS 20W50 for the engine
B&M trick shift for the primary
Spectro FS 75/140 for the trans
None of these are available at the local auto parts stores and didn't see fluids other than DOT5 for brakes at WSW.
I assume there is an online source but before I start looking on my own was wondering where everyone on here goes to get all their stuff hopefully in one place at reasonable prices.
On a side note, those of you who've tuned/modified Porsche/Audis, you're probably familiar with ECS in Ohio? Prices are a little high but they sell pre-assembled"kits" for year/make/model that are well worth the extra cost since quantities are measured and has everything at once.
For example, let's say I logged into WSW and selected BDM 2005 Chopper, then I could buy a Primary Oil change kit that would include:
- Recommended fluid in the amount needed.
- Inspection cover gasket
- Drain plug seal
- Liquid teflon
I doubt anyplace online is doing that for BDM but I'd settle for getting all my fluids in one place then going to Home Depot for the liquid teflon then ordering the rings and gaskets from WSW
Was targeting:
- Drain plug seal
- Liquid teflon
