looking for a how to on trans????
outdoorsman26
I have a 07 mastiff and the main shaft bearing broke:bang: so I ordered the parts from baker, and now im readyto put the shit back togather, only problem I see is how do you align your trans?:confused::confused: book says I need sum laser thing:loony: is there a different way???thanks matt
phatchopper300
I just wanta ride
Maybe bigdogtech01 (Andrew) will chime in. HE replaced all my bearings and seals Aand have suggestions on how to do it. Just sayin'
outdoorsman26
well I figured seeing as I didnt move my motor if I left my trans loose and bolted my primary to the motor then my trans then tighten my loose trans bolts it should be straight??? sounds good to me anyway????
phatchopper300
I just wanta ride
Thats exactly what I did when I had my tranny referb. Just made sure that the shims on bottom of tranny was the same when tranny was taken out.
