I think retaining wall with the top finished that smooth, ya gotta love those concrete pumpers, man do they make it easy instead of wheel barrowing, but then again you need one of them for the walls
Ker, yea the seat wall caps were a lot of extra work and without a pump we would have screwed up all the forms, and yea, that young man busted his ass!:2thumbs:It does not take much of that work to catch up to you.
It's big enough to be a huge pool! 24'-0 X 40'-0, yea franco it does look like that now that you said that!At first I was thinking a swimming pool!
Yea, was definetly going with the Acid stain. But have you used clear coat epoxy over acid stain before?Jonathan, when I stain anything I get my materials from a supplier here in Sacramento called "Spec West", here is there web addy, Home | Spec-West, so back to your question, first I would recommed using an "acid stain" you will get the best look from that type of stain, the crap from Home Depot is shit, don't use it! Anyway, get a high quality acid stain, I use "Brickform" produts but there are alot of others out there, what you need to do is follow the instructions for that product, if you don't and there is a problem then you are screwed, it's vary's a little but they are all basically the same, get a high quality pump up spray can, "not anything from home depot" mix the staim as per mfg instructions and apply in an even coat trying not to get any puddling if possible, let it dry however long they say and then you need to "neutralize" the acid, you can get the neutralizer from your supplier, after your done let dry and apply your sealer or epoxy clear coat and your done. Keep in mind that when you apply your stain it darkens as it drys so don't over do it on the first application, take your time and do it in stages untill it's the desired color, also your sealer will darken it up a little too, hopr that helps!![]()
Going back to my regular job tomorrow:2thumbs: I am a Superintendant for a Bridge Contractor, and I agree, it's a young mans job, I just did it since it's a friend of ours and they basically begged me to do it!I was so over all that shit 10 years ago. I'll push a shopping cart before I'll ever do that again. Its a young mans world unless your a non-working foreman or Super...LOL.
Thanks Jonathan! it is a combination of me and my partner, he is by far one of the best at flatwork I have ever seen in my 32 years of doing concrete!You did an amazing job! Very gifted!!!
