Lifters again
Banned
How much? Do you just add it to the normal qty of oil or what?
I just put 1/3 to 1/2 qt in my bikes the dog & softail hold less so 1/3 qt for them the street glide holds more so about a 1/2 qt for it . my autos get a full qt. I just fill to the full mark after installing lucas.. but I guess you could drain out the amount you wanta install then add it .. dont over fill
FWIW I popped out the rear lifters on mine and gave them a good cleaning, they had a lot of gunk in them causing them to stick. Problem solved, for now.
I'm all over the tappet screen now also:)
Makes you wonder how all that gunk got in there and what to do about it not happening again! :D
Oldskuul
Dont buy a used bike for starters. I find that not many people maintain their
stuff like I do.:bang:
PS. I use Marvel Mystery oil as an additive in the oil but not in the gas any more
now that I've found Startron.:2thumbs:
nine lives
I adjusted my lifters again today, seem to be better but I only was able to ride 5 miles. We should not be having these issues, after all the motors are purpose built to be 117" They are not a punched out 80" with 12-1 compression. If I still have a noise, I will do a tear down over the winter and fix the problem. After 50+ years, S&S should have there shit together and not have these problems.
nine lives
My lifters seem to be quietest with 3 turns. Did about 400 miles and sound pretty good. Even rode in center city Philly. in 90 degree+ heat and was not really noisy. I think three turns from zero is the sweet spot.
nine lives
I'm just saying S&S should have there engine's set up better. If I build a motor run it for a while and it's making noise (and it doesn't have soild lifters) I would make some kind of change, and that's just me building one engine, not going into production.
Just Sunday I rode with a friend that built a 80" evo-engine stock bore, big cam major head work (14/1 compression) can only run 114 race fuel, and besides exhaust being loud as hell, motor it's self was quiet.
Don't get me wrong, I love my motor, I have it pretty quiet now, I'll keep tuning it till it's perfect (I'm anal about these things) Over the winter I'll probably do a tear down check tolarances and see what I come up with. I just don't think these motors should come out of the box making noise. Just sayin.
Nine, you know that for the 05 though about the 07 years S&S just provided the lower ends and BDM built them up to there specs trying to meet EPA demands I imagine. Just saying. :D
nine lives
Didn't do a winter teardown, no need. Motor sounds good now, small amount of piston slap sometimes....really happy with the motor overall, definitly quieter with 20,000 miles then with 1000.
Five Five
Glad it worked out nine, with a simple adjustment :up:
firedog19
Just a thought. I had a springer with a 95 kit and woods cams and they were noisy, too much so . I had the local harley mech check it out and it ended up being worn rocker arm bushings. He replaced them and there was still some noise but not nearly what it had been.
