LIFTER BLOCKS
leandean99
i need to rechrome both lifter blocks, can i adjust the pushrods short enough to pull the blocks out or i have to remove the rocker boxes and pushrods? thanks dino
You will have to remove the pushrods as you won't be able to get enough clearance to pull the tappet blocks. You are also going to have to remove the camshaft cover and camshaft to get the lifters out.
BTW Tappet Blocks are polished aluminum not chrome though. Unless someone chromed yours.
john sachs
Why would you remove the cam cover, etc. to get the lifters out of the lifter blocks ??? :confused: :down:
John
John
I'm thinking the push rods are the stock ones and therefore won't give you enough room to pull them out? I suppose you could cut them and install new pushrods. IMO the cam is easier to remove than the rocker boxes.
I guess my wording is off a bit you don't have to remove the cam to get the lifters out. But to get the pushrods you need to either cut them, remove rocker boxes or remove cam shaft & lifters.
liferider
Looking forward to retirement
I agree, but if you are ever going to do cam work in the future or deck your heads. Might want to cut them and install the adjustable push rods. There not hard to install.
Brew
If it's an S&S engine you have adjustable p/rods in it. AND,It is easy to pull the top rocker cover, and rocker sadde to remove the push rods. Then you can remove the lifter blocks. You're stressing over a basic simple job... :eek:
John
:iagree: with what John states, you can do it that way. While you have it open put some quickie push rods in so you wont have to pull the rocker covers in the future... :D
BadCo
Got all the parts together to convert TP's to S&S boxes. Doin' new lifters as well. Now gettin everything else together so I can do this in the warmer weather. Got most except inverted torx socket set.
Anyone know what size the inverted torx socket size is for the tappet block bolts? (E-something.)
Thanks in advance..... AND... Merry Xmas !
Going to take a guess. If it's '90's kind of hd inverted torx looking head I think the size is a 12 point 7/16th box end wrench. Concur with John and Brew. Rocker box gasket is cheaper than a set of snipped off pushrods. Cam drop is more a PITA.
Yep, i found a small 12pt socket that did the trick
BadCo
Thanks guys, but I have a few months before I get into this and was looking for the actual size for the inverted torx socket.
I just bought a cheap set off amazon for like $18.
BadCo
Getting real close to changing over the TP's to S&S .Looking at an exploded view of the s&s rocker boxes on an s&s pdf. It shows 2 dowels in the bottom of the rocker boxes (#18 on the parts list). I bought RB's from Eric and Donna and there are no dowel pins on these. Should there be?
My first time taking one of these monsters apart.
On the parts list, the part number says N/A. Not sure if that means "not applicable" or "not available". Big difference.
Thanks in advance.
