LED License Plate Board?
Utopiapga
Ok after searching far and wide on the World Wide Web I have struck zero on where to find the 4 LED light small board that lights up our license plate. I now only have 2 of the 4 led bulbs work on it and was wondering if there are replacement boards out there or do I just need to get the soldering kit out and run by radio shack and replace the LED Bulbs myself?:confused:
Thanks for any help!:cheers:
Hollywood.
I had the same issue last year, what I did was I went to my local small town electronic store and talked to the guy behind the counter, he matched the LED lights to the small LED board, and I found a guy to professionally solder the new ones , (I replaced all four), and it cost me, $20 for the guy to solder the lights and just a few bucks for the LEDs, and now they work great! No more issues!
Utopiapga
Yeah thats what I thought, I did the same thing to my temp controls on my car. You had to buy the whole set up for freakin $350 just to get 2 LED lights replaced. So pulled the board and went to Radio Shack and got the LED lights and just soldered them in myself!
Thanks Perro Grande aka Big Dog!!
Utopiapga
You can by a new board from BDPP or do the LED Replacement like I did. I even replaced mine with blue LED vs white. I bought mine from Component LEDs | Super Bright LEDs for .65 cents each. Send me the board and the LEDs if you can't find anyone to solder for you, happy to help.
Thanks rmgrounds do you remember the exact bulbs you got for the replacement? I can do it but if I run into trouble I will take you up on that offer thanks!!:cheers:
Brew
Radio shack has the LEDs I replaced all mine on my Ridgeback...:D :2thumbs:
Part # 276-0017
5mm - High Brightness
White LED
Petermurphy
Ok after searching far and wide on the World Wide Web I have struck zero on where to find the 4 Peimar led light small board that lights up our license plate. I now only have 2 of the 4 led bulbs work on it and was wondering if there are replacement boards out there or do I just need to get the soldering kit out and run by radio shack and replace the LED Bulbs myself?:confused:
I think there is no way to replace them. Have some new ones now
BigMike
Big Mike
It is just go to job lot store and get one of the muti arm pinch clip things that they use to make flys for fly fishing .There also is a magnifing glass on it to hold the board.
phatchopper300
I just wanta ride
I have an extra board that you can have if you want it. If I remember all leds do work if not you are still welcome to have it. Let me know and PM your addy.
Sent from my DROID RAZR using Tapatalk 2
phatchopper300
I just wanta ride
Board is on its way. I did include some black and red wire but not long enough to do the whole job. Hope you can use and get you fixed up.
