RossPerformanceMotorcycle
Wanted to show off this pretty radical project we had, it's an 06' K9 that was stretched and raked for a 38 1/4" over inverted front end. Had to modify the tank a little by relocating the fuel valve bung and filler neck due to the frame angle. We raised the compression on the engine to 11.4:1 including a .650" cam with all the bells and whistles; i.e lifters, valve springs, guides, T-Jet, and programmable ignition. Powdered and had the heads and cylinders diamond cut, and machined a set of Ridgeback wheels to fit. After some miles were put on, it was brought back for a once over and to throw a set of custom exhaust on. Finished it up with a good test and tune. Check out the socials to hear it fire up and idle.
