troppushcet
I would start with 76 main and 32 intermediadte.
It smells like it is running rich and when I started it up after I got the pipes put on it would blow a little fire out the pipes. I also can wipe the tips off of the pipes and there is black residue present. I don't know if any of this helps at all?I don't think those mods would really call for anything to be done. The D&M sucks for perfomance. Your not really getting more air in with it. Pipes alone probaby not much difference either. If it runs good. Ride it.
Is this all the time like when you pull up to a stoplight or just in the garage when you're starting it up? If it's the garage are you using the "enrichener"?It smells like it is running rich and when I started it up after I got the pipes put on it would blow a little fire out the pipes. I also can wipe the tips off of the pipes and there is black residue present. I don't know if any of this helps at all?
Ya I can smell it at start up and say I ride it to work (about a 25 min. trip) I can smell a little fuel when I arrive. I have used the enrichiner in the past, but have learned (on here) that it dosen't get cold enough down here to use it so I have stopped using it. When I get off of this set of nights I will either drop the bowl and get the jet sizes ar just take it over to a local shop and let them dyno and tune it.Is this all the time like when you pull up to a stoplight or just in the garage when you're starting it up? If it's the garage are you using the "enrichener"?
bad bad bad![]()
You need to drop the bowl and tell us what jets are in it.
Thanks for the reply John.......It sucks to have an air cleaner that looks good, but is shit on flow. I am going to give it a try and if I am not satisfied I will go back to the drawing board. They did mention that they would adjust the timing as well.That A/cleaner is like putting a cotten swab in 1 of your nostrills.They look good ,but suffer in the air flow dept.
I've seen as lean as 28 intermediate,and a 68 main jet on reworked 113" motors.I'd start at 29.5 intermediate and 70 main. Jet it on a dyno with a sniffer in the pipe.Your dyno tuner will know where to set the fuel curve,and DON'T FORGET THE TIMING.:up:
John
rhino got it.With the extension kit,it can't be beat.Just a note, the stock S&S is actually a great air intake
I have no doubt that it is a great air intake, I just wanting something that looks a whole lot better.Just a note, the stock S&S is actually a great air intake
The dyno can read the exhaust gas and determine which jets you need.
