When in doubt always drop 2 jet sizes because a lean condition is much easier to diagnose than a rich condition. A rich bike will run fine all day long, and in my experience most guys are running rich without realizing it. If you have an open intake remove the bowl vent. For heavy decel popping try opening the mixture screw 1/2 turn at a time, but I wouldn't go farther than a full turn out. S&S has an excellent how-to on their website. To jet a bike here's how I do it.
Turn off the accel pump
Warm it up and adjust the mixture screw
Take it out for a ride to see if anything is obviously off. If not, drop 2 sizes on the intermediate jet. Always make bold changes, one at a time, until you dial it in. Once I dial it out of lean, I'll usually go up one more jet.
Do the same for the high jet, which is pretty simple. The S&S WOT test is easy and quick. Get it lean, then dial it up
If you are running a very free flowing air cleaner, you may get a stumble where the intermediate and high jets overlap, somewhere around 2k rpms. If this is happeneing, try opening up the air bleed until you dial it out.
Adjust the mixture screw again. With really short pipes opening up the screw a bit should help with popping.
Adjust the accel pump
