The the input has been great.This is what I have at this point wiring is correct the starter is spinning Clockwise ,it engages the clutch and bam the jam nut spins out .I have replaced the bolt ,drop red threadlocker ,torque down 60 inch pounds. about to break out welder !
Thank again for all the input
Frustrated !!!
If your starter is turning clockwise looking at it from the direction in this picture it’s turning the right way.
I don’t believe it’s possible to have the wiring wrong and make it turn counterclockwise.
That would have to be done internally on the starter which would make it a factory defect and it would
never have turned the correct way. Here’s a dumb question have you got the bike to turn over at all or just the starter. If not Pull your spark plugs out put it in six gear leave the clutch out and see if the motor turns over when you try to roll it forward. I’m just stabbing in the dark here it’s hard to diagnose something when you don’t have it right in front of you and not a whole Lotta information to go on But you are in the right place to get it figured out. There’s a lot of people on this site with a whole lot of experience on these big dogs . And just so you know I’m not one of them. LOL
I’m just saying if your starter is turning clockwise like it supposed to and you used red Loctite on that bolt and you got the washers on there with the locking tabs locked into the gear drive and the other ones locked on to the bolt then it sounds like The bolt is worn out and/or locking tab washers are worn out or something in the motor or transmission is locked up and the initial hit of that starter is busting that bolt loose and spreading them tabs out to let it back out .
But there again I’m not an expert on these dogs so I’m not sure exactly what kind of starter they used on the 03 but without Pictures or seeing it I am assuming yours is like the Harley starter that has the bolt and locking tab washers.
Not like the picture below.
But it still should turn clockwise.
