lee
Well I'm half way through on the installation of the S&S IST ignition. What a pain in the ass! I bolted the module to the underside of the battery tray. The main issue with this was that it wouldn't fit between the tray and the the connection of the positive cable to the starter. To get over this I put spacers in to lift the battery tray - hopefully the battery will go back in ok and the seat won't be a problem. If either of those things won't work out I'm in trouble!
I've installed the new crank position sensor, the knock sensor, the head temperature sensor and the map sensor. No problems there except there is a bracket and screw with the map sensor that I have no idea how to use (no pictures in the instructions - HDLarry??).
The kit connects to a stock HD wiring harness - we haven't got one of those! There is an additional cable with the kit to get over this with 3 wires coming from it - they are power, ground and tach signal. There is a connector coming from the TH ignition with these same 3 wires going through the EHC - my plan is to take the 3 wires out of that connector (on the module side) and put the 3 IST wires into it and reconnect - PLEASE LET ME KNOW IF THIS MIGHT CAUSE PROBLEMS THAT YOU KNOW OF.
Tomorrow night I am hoping to install the new coil harness and connect everything up and try to get it started - wish me luck! I obviously need to get the tank back on so may take time - I also need to do my shrinkwrapping.
Another question I have is that the instructions say to remove the cam position sensor in the nose cone - in the 05 bikes there isn't one - IS THERE ? It also says to remove the VOES switch between the heads - DO WE HAVE THAT? IF WE DO WHAT DOES IT LOOK LIKE?
I have taken some pics along the way and will try to do a "how to" when I'm done - I seriously doubt it will be a Gas Man quality "how to" but will do my best.
If anyone can answer of these questions in the above it would be immensely appreciated.
Cheers
Lee
Cheers
Lee
