Posted by mariovitanza
Moved to own post by Dakotabos
I have an 04 Big Dog Chopper, a few weeks ago it shut down while I was cruising at 35 - 45 MPG for no reason, several times. Took it to a local bike mechanic and of course he could not get it to stall out. Got the bike back went on a good 500 mile road trip, ran beautiful !! I figured the problem was solved. P.S. While on this road trip the headlight went out, check old bulb (bulb checks good on bench check), put back on bike(does not work), bench checks good again, purchased new bulb, does not work on bike. Then all of a sudden the stalling problem is back, starts, runs a few seconds then cuts out, and does not start again after a few more starts and cutting out (battery is new !!). If I let it sit overnight it starts again a few mote times then refuses to start at all (no spark at spark plugs). The red light by the silver box where the troublrshooting plug is plugged in does not turn red until the bike is running, when it stalls out the red light on this box shuts off.......................Help what should I look for, most bike shops do not want to touch these bikes for some reason. HELP !! HELP !!
to the BDB Forum
