Is it the clutch or belt?
Kdub
When I'm riding slow and easy bike does fine. When I hit the throttle hard bike acts almost like its in neutral. My first thought was loose belt like the power wasn't being transferred to the tire. Now I think about it I'm wondering if clutch is slipping. I'm not overly familiar with the clutch system. It doesn't creep at all. But it is a pain to find neutral when stopped, but that is nothing new. I tightened the belt, but I didn't think it was all that loose. No guage for an exact measurement. I'm gonna test it out today. Any thoughts?
BadBrad
2005 Pitbull
It could be that your clutch plates are worn. First, I would check the adjustment on the clutch pushrod. Make sure it's backed off the pressure plate 1/4 turn before you tighten the locknut back down, then adjust your slack out of your cable.
Kdub
I'm thinkin Yall are right. I took it for a spin today and didn't have any problems but I wasn't romping on it either. I'll check out the adjustment next time she's in the air. Thanks for the thoughts.
