I've used it before but switched to the white mother's paste a while backIf your using the "Blue Magic" metal polish, that I think you are....it has alot of ammonia in it. I have a container of it also. It does work really good on the aluminum. But over time it will damage parts. I usually use it (if I have to) then seal it with another good known product.
Been using Master Formula and it's the best cleaner I found.I use this stuff called Master Formula very little rubbing the more you use it the better it does lol
Hit it with BrakeKleen, that shit cleans everything (maybe try some on a cloth)Been using Master Formula and it's the best cleaner I found.
Specifically, I can see the removed grime "swirling" but as I wipe it, the towel seems to "spread" the grime instead of absorbing it or pulling it off the component.
Water doesn't rinse it off.
So while the Master Formula does a great job of removing/extracting the grime from the component (especially the rear struts), the battle is getting the loosened grime off the component.
I end up going through a lot more towels than I feel I should
on the wheels that would be fine but where it need it most is those struts, man they get dirty. but would the brake cleaner damage the paint?Hit it with BrakeKleen, that shit cleans everything (maybe try some on a cloth)
I'm searching online for the 3M label that states this and am unable to find a 3M cleaner that states this on the label. I think I see a couple different 3M brake cleaners and want to make sure I'm getting the right one
Pretty sure most brake cleaner won’t hurt your paint. Just don’t get it anything powder coated.I'm searching online for the 3M label that states this and am unable to find a 3M cleaner that states this on the label. I think I see a couple different 3M brake cleaners and want to make sure I'm getting the right one
will Wizards hurt the paint?If it’s aluminum use Wizard , if it’s chrome go with coke and aluminum foil. The chrome on CeCe’s rear Sportster shocks were all rusted. The coke and aluminum foil made them look like new and then I waxed them. View attachment 84817
