Ok I did search but I would like some advice.
Changed from a 546 to a 585 cam
Went from .295 intermediate jet to a .31.
I also upped the main jet.
Set idle at 1000
Turned accel pump in to lightly seat.
I turn mixture screw in till it stumbles.
I turn it out and I can screw it all the way out and it will not stumble.
I set it 3 full turns out.
I then adjusted the accelerator pump screw. I am 4 full turns out to get good throttle response.
It seems to run good but wouldn't this mean I need to go up another jet size on the intermediate?
I checked for intake leaks and made sure the exhaust was tight.
Thanks for any insight.
I have jetted many v-8's but this is a slightly different animal.
Set idle at 1000
Check yer plugs and adjust.
