intake manifold
T.Byrd
I'm writing to see if any one can help I'm going to buy a triple X, G carb for my 05 chopper it has a E on it now.What I need to know is do I have to
buy a special intake from Big Dog because of the heads on a 05, or
can I get the same intake as the rest of the 117.
I think Alhall and I'm sure Sul have been through this. I can't remember what is what on each year for this. I know that there is a different intake for some dogs compared to the S&S standard
Yes, you are going to need the larger bore size manifold for the G carb. Triple X will probably be able to get it for you or you can check with Vicky or Nelson.
Enjoy the Triple X carb,
Ray
Like ray said you will need to replace your manifold. From what I was told the o6 and o5 manifolds were different and starting in 07 the manifolds were the stock S&S ones like in o4 and previous. So the question should be will the 06 or the 07 be the replacement manifold for an 05 with the restrictor plates removed? I know sul has an 05 and he probably has a number. But this has been done a bunch a times so I'm sure vickie will know or just call any dealer as I'm sure they have done this mod as well.
