Installing compression releases
syclone
I just bought a set of compression releases for my 2003 Bulldog. I now believed that I have everything needed to do the work on my bike. Where can I get the starter relay for the 2002 and I was hoping for someone to tell me where to find the wiring diagram for the 2003 Bulldog. Also where is the relay located?
Thanks in advance guys.
Edwin
LDO
The Cleaner
Syclone,
I just spoke to Tonya's parts guy yesterday regarding the same mod to my 03Mastiff!
I'm at work right now but when I get home, I'll send you the info I got from them along with a big dog memo on how to wire up the stuff. According to Big Dog, you will also need a new speedo sensor as this mod makes your current sensor fluctuate alot.
Also,
Did you get the special wrench for installing these? There's one that has a groove or something in it for the wiring. It allows you to install the c/r's with the wiring intact.
LDO
syclone
I don't know what I need for special tools, I am waiting for the parts but I have a few oxigen sensor sockets (they already have the grove), I want to see what size I need. Worse case scenario I will have to use a wrench. Can you tell me how much is for the speedo sensor and the part number. also lacation of this sensor.
Thanks a lot and I will look forward for that information
Edwin
:whoop:
rhinoevans
I am currently bidding on EBAY for a set. I have looked at the wiring diagram from the install instructions and all I plan on doing is splicing the wiring harness into the green wire that runs from the EHC (Starter Relay) and the starter selnoid. And then ground the black ground wire. That should be all there is to it. Dont know anything about the speed sensor issue. I have a 2002 and their is no mention of this in the S&S install instructions.
LDO: Please send me the memo. zee06@cox.net
syclone
I like this approach of your, I love to keep things simple. I wonder why would the releases cause any problems to the speedo. Once they are off why would they create any interference.
Edwin:confused:
syclone
Any more info on why I should not install the green wire directly to the starter wire on the bike......I am sure some one here will know. Also why would the spedo couse problems......
:hi:
Edwin
