Hurricane6767
This is my 2008 big dog k9, here is what happened, I pulled into a CVS parking lot, with an above average grade, the bottom frame rail hit the flat, I think it bent it up just a hair where the top of the bottom frame rail was rubbing the bottom of the inner primary, I started noticing a leak under my bike, after looking at it, I could see oil between the bottom of the primary and the frame rail.. so I took it all apart, but I cant see a hole in the inner primary cover, but you can see where it was rubbing, do I just weld this up? It has to be coming from here...
