Inner Primary Case Bolt Size?
Utopiapga
Can anyone tell me if hand what size case bolt I need for the Inner Primary at Position 3 according to the service manual? Says 1/4 or 5/16 but does not give any lengths or details.
Mine keeps comming loose there and I have now lost it somewhere on my last ride all together. Guess I need to get back into habit of checking all of them again after each long ride.
Thanks
Posted via Mobile Device
Viking
Biker
The only one that is remotely close to being in the 3'O Clock position is the rear inner primary who mounts to the transmission. That is a 5/16-18 x 1-1/4 bolt, torqued to 16 ft lbs and uses locktite 2440.
Utopiapga
Thank you! It's not the 3'oclock position but the #3 position according the the service manual. It is the front lower of the two you can see behind the forward control.
But thank you for the help!!
shovelshot
You must be talking about the bolt holding the outer to the inner primary. I lost that one several times as well. If I remember it is 5/16-18. I think I bought 1-1/2 or 1-1/4 long.
Utopiapga
Yes that is the one! Got it fixed!! Easy fix didn't have to remove primary lets hope it holds up better this time but will definately keep a closer eye on it this time!
Thanks for everyone's help!!
