G Geoffrey2u New Member Aug 23, 2014 #1 I have a '02 Prosport and need to replace the ignition switch. The only thing I can find is a 3 post switch and my pooch has a 2 post switch...any ideas on how to set up the new switch or can find a OEM switch ?
Doggin it Active Member Aug 23, 2014 #2 Franco will be with you shortly. Check with the vendors on here.
francoblay1 The Spaniard Aug 23, 2014 #3 Its been discussed before, someone will chime in shortly :up: Meanwhile, check THIS out.
BWG56 Guru Aug 23, 2014 #4 francoblay1 said: Its been discussed before, someone will chime in shortly :up: Meanwhile, check THIS out. Click to expand... :2thumbs::roll:
