Electraglide1800
Hi all, I have a question that hopefully someone will have some ideas about. I've recently purchased a 2005 Big Dog Chopper. On a recent ride the bike just cut out and no electrics were available, turn the key off then on and everything fine, it did this twice on the same ride. After some digging around the item that appeared to be causing the issue was the Ignition Switch - Harness Jumper Part # 172-000001-00, after dissecting it it was obvious that the resistor had a broken wire at one end. I removed this item and everything runs fine, then bought a new resistor and soldered it into place, two miles down the road and the bike cut out again, key off then on and all fine. My question is what does this resistor do and will anything be harmed by it's removal ???? Thanks in advance for any replies.
Good info
