Ignition module
Murf6261
Hello. New the site just finished up the rewire on my 07 mastiff and I'm stuck with the red/yellow/blue plug of off ignition module no wer to plug. And when powering it up no tach light. Need help. Thx
bearman
Red/yellow/blue from ignition module goes to coil. I think blue is front cyl, yellow is rear cyl, and red is power to coil.
Tach signal comes from green wire on ignition module.
07bigdog
07BIGDOG
If you are wiring in a PDM kit you have to use the existing wire that goes from the ignition to the coil. It is not supplied with the kit.
Murf6261
Thx guys for the response. The wiring worked and it alive. Just need one more thing can't get the tach to lite up when rev. Thx
bearman
Check the continuity from green wire at ignition module to the speedo connector yellow wire. Green wire at speedo should be for neutral light. If everything is wired up correctly then you might need to take apart the speedo and look at the circuit board. Do a search on here, it is a known problem that sometimes the wires break where they are soldered on the circuit board in the speedo/tach.
