Idle cable hanging loose
IRONHEAD
I noticed while Im riding the idle cable at the handle bar connection is moving around alot. The more I twist the more it hangs out. If I adjust the fittings on the cable to tighten up will that have a negative affect on the idle speed? What does an idle cable do anyway? :confused:
BBChopper
Supports 2 Disabled Vets
The throttle cables are pull and return they have no affect on Idle adjustment unless they aren't adjusted properly.
ringo
mine was doing the same thing despite there being a small clip on the end of the cable in the switch housing that seemingly should prevent this. Just re-adjust the cable making it shorter.
