08mastiff
Anyone out there know of an aftermarket replacement for the idle air control solenoid that is reliable. The OEM S&S is $160. Thanks.
Idle is all over the place, mostly had to give it throttle when stopped in neutral because it dropped too low and would stall if I didn't. The check engine light would come on but was ok when I was moving. I had the tank off, pump and regulator are good (even swapped them out with a spare I had to double check), filter is good, no loose liner pieces in tank. Flushed out the fuel injectors. Put it back together and my idle issue still persisted. Took IAC out and cleaned it. It ran better but when I would pull the clutch in it would idle high until I came to a full stop. Then it would idle normal but the good news is the initial low idle problem went away. Just a guess but I think the solenoid is sticking. I should check for maybe a vacuum leak too.. Thanks for your reply btw.Try to google the numbers on it.
S&S is the OEM, but didn’t actually make most of the sensors.
Side note, what makes you think it’s bad? They are very robust and rarely fail. Most issues are just build up and can just be cleaned with brake or carb clean.
So, I just cleaned it again this morning and sprayed some lubricant in there to soak a bit. After work I will go home and see what it does. I do change gas often when I fill up, but never at a no name gas station. I put the startron enzyme fuel treatment in with every tank full as well. Maybe I'll try the seafoam one of these days. I have 39,000 miles but I will check for vacuum leak because I had the intake and injectors off. Maybe something didn't seal well (even tough I was careful). I'm am running my stock ecu now but I also do have the after market replacement I bought from Curtis a while back. Obviously I am EFI, so no jets or carb bowl to worry about. Thanks.When the light goes off fandango, it says from wire end to wire end, there is no open, short, is the integrity of the wiring loop. Have to read that light saying, it's not the black box if it can code, make the bike run, and shuts the light off, dan you know fandango, it's not the sensor either.
So you figured it out, being a stuck plunger sticking. Wires inside the sensor are not open or short. This is where you understand analog means many, and digital means a single digit. Where 4 pins at the sensor show 1(+), 2(-), 3signal in, 4signal out.
Signal out of the sensor are many. Black box receives this as 00110010101 or analog. Plunger is moving up and down constantly.
Signal out of the sensor being one of the pins being open or short sends nothing, meaning 000000 or the single digit over and over.
Where jwooky says those sensors are this side of bulletproof, being you cleaned it up enough to shut the light off while it runs. The sensor shows good. Might a change of gas to maybe Shell or Chevron with a detergent cleaner that unsticks the gummy buildup of a bike long in the tooth, maybe sits during winter, and all that does is clogs up the jets with gas left in the carb blow.
For the idle to return via cleaning robustteass, show me a vacuum leak if idle returns?
Hoook the system up to Protune and see what it says and displays.So, I just cleaned it again this morning and sprayed some lubricant in there to soak a bit. After work I will go home and see what it does. I do change gas often when I fill up, but never at a no name gas station. I put the startron enzyme fuel treatment in with every tank full as well. Maybe I'll try the seafoam one of these days. I have 39,000 miles but I will check for vacuum leak because I had the intake and injectors off. Maybe something didn't seal well (even tough I was careful). I'm am running my stock ecu now but I also do have the after market replacement I bought from Curtis a while back. Obviously I am EFI, so no jets or carb bowl to worry about. Thanks.
