07-Mastiff
I need to adjust my idle rpm up just a little because when it reaches the idle rpm it drops just below 1000 rpms to a point where my tach starts flashing at me warning me my idle rpm is to low. I look in the manual to make sure I was going to turn the correct screw and it also said how to make adjustments slowly. My problem is that it doesn't seem to matter how much I turn the adjustment screw in either direction it doesn't change the rpms up or down. can someone please explain whats going on and how to fix it. I really need to get the RPM idle correct because the engine die's when I stop if I don't keep a small amount of presure on the throtle. Thanks
