Ray
I talked to a mechanic the other day about adjusting my valves and told him what it was doing. He said he believed the valves didn't need adjusting once the push rods were locked and he said I had Spark knock from the ignition needing resetting.
It runs great, starts great, but at certain higher RPM's you can hear sounds like valves rattling in the top of the motor.Mine is a 107 and he said the 117's were worst. I let off throttle, rpm's go down just a tad and it goes away.
Ok, I trust you guys thoughts on my scooter getting fixed correctly. If it is an ignition issue should I let him reset it, hope it lasts, or get the crane ignition and find someone to install it to get the most out of the motor?
I am asking because of being unsure which direction is best, I am not sure so I ask.
Thank you in advance,
Ray
Ray
