I need some transmission know how
speedster
I have a 07 k-9 and just had my clutch hub nut back off. I pulled the clutch pack and inner cover to clean and check for damage and found that the bearing on my transmission output/ sprocket shaft was shot. does anyone know if there is a how to or can give some info on how to go about changing the bearings out in a baker six speed. Thanks, Speedster:confused:
phatchopper300
I just wanta ride
You can send it to bigdogtech1 a member on here that knows these dogs very well. He is in NY. I have mine with him now. He has all the seal and bearings to rebuild the tranny.
Coolbreeze
I can rebiuld it for ya. I'm in Ohio. The Baker 6 speed does require there specailty tools. I have'm. I've rebuilt many BD tranny's.
speedster
Thanks, I called baker and they sent me all the part and scymatics on my tranny. Im gonna look at it this afternoon and decide which way to go.I really want to do all of my own work, but dont we all.
jimizee028
TRUE COLORS COLLISION
I am in the very same boat...any help or advice you can give me would be greatly appreciated...Trans seal and bearing so wasted it chewed the hub up...let me know how you handled this......
wyatt580
Hay jimizee pm bigdogtech1 he has always taken time to talk to me and help me. Can't beat it you get to know your scoot from an expert. And if it's to much he's the man. also has a modified spring for the clutches no more slip. Talk to him can't hurt.
Scott@BAKER
FYI, I have a PDF file of the driveline section out of a 2007 BDM Service Manual. Let me know if you want me to send you a copy. Also with it I will send the cross reference sheet for my part numbers.
