Did you remove the set screws? Soak it with some WD-40 or similar. Then use some rubber gloves. Replace it with anti-siege in the threads. Lots of bug juice in there!!!cant get trim ring off!! any ideas thanks
still no luck with rubber gloves two sided tape w-d 40 any other ideas thanks shouldnt be this hard to change a headlight!!!!
Then trace the wire back to the main harness between or under the seat. You may likely have a grounded wire. :2thumbs:HELP OK after four days got the dam headlight apart!!!!!!!!thanks for everyones help!! replaced bulb but still have no low beam tried two bulbs anybody know why thanks
