How to remove pins in electrical harness
Chris
Hey guys,need some help. How do you remove the pins in the electrical harness? I just can't figure it out. :bang:
BigDogBro1
Made in the USA
Hey!
I think that's like a Molex connector that is released from the end opposite the wire. There is a special tool but you can find a small aluminum thin wall tube from the hardware store or hobby shop that will just slide over the connector contact and flex the release tab(s) inward. then you can remove the contact from the housing.
A very small screwdriver will also work if only one tab on contact.
Ray
Agrees try Radio Shack and if they don't have it, they might be able to point you in the right direction.
Ray
