His is different than your as you got a slammer drive no bolt nor do you have to pull primary coverI have a 2006 but you should not have to remove the nut-bolt from the shaft. It should bolt in from the other side.
I tried to slide it in the clutch basket but it still turns.engage starter gear (slide forward) into clutch basket (gear) that should hold it with enough force to un-tighten the bolt...works for me :2thumbs:
That worked thanks,I was afraid of damaging the gear.Just wedge a broad flathead screwdriver in there and hold some side force on it. That's how I always do it, you won't damage the gear, it's not fragile.
