How to bypass computer
Antcoy420
No spark, just installed new cam sensor since I was told if the led light isnt flashing on the thunderheart when cranking that's what it was... now the led light comes on when key is turned, but stays on.... is there a way I can just bypass the thunderheart
Rottweiler
No
Double check your wiring on the cam sensor. Sounds like it is always sending current to the thunderheart.
roadie1389
It will be on depending on where the trigger it. if you hit the start button it should flash. If it does not flash then there is something else going on. No, the thunder-heart is the ignition system, you need it or you can replace it with another brand/type but this is the ignition layout you bike needs.
