how do you keep the seat on???
Roaddawg
Purchased a 2 up seat for the '05 chopper. The seat won't stay stuck down. Only two suction cups at the very back and the front tab of the seat will not stay in the metal slot. Anyone else with this issue???
Little-Boo
:hi: What I do is align the front tab and push the seat at about the middle as if to bend it and push forward till it's as close to the gas tank as possible and then I lower the back part and it stay on no problems yet.
Carlos :2thumbs:
MN K9
Make sure the fender and the suction cups are clean. They will stick better and not mark up the paint.
Are you saying it's not fitting the frame? It should sit down tight on the frame and not require any thing to hold it down. If it doesn't sit down tight then I would say you have the wrong model.
:D :flag: :D
dingo
First 50
My two-up was sliding around once while riding in the rain with no passenger.....like MN K9 says, the suctions cups need to be really clean.
Just one other thought - Do you have flat black paint ? I know that with some flat black paintjobs, you need the protection tape in order for the suctions cups to stick......good luck
