What I do is align the front tab and push the seat at about the middle as if to bend it and push forward till it's as close to the gas tank as possible and then I lower the back part and it stay on no problems yet.Are you saying it's not fitting the frame? It should sit down tight on the frame and not require any thing to hold it down. If it doesn't sit down tight then I would say you have the wrong model.Purchased a 2 up seat for the '05 chopper. The seat won't stay stuck down. Only two suction cups at the very back and the front tab of the seat will not stay in the metal slot. Anyone else with this issue???
Put some moisture on the cups, they wont move.
