05 old dog
ok...been tuning two strokes for 12 years...mikuni, and kiehin carbs and am use to instant throttle response...so how crisp should the throttle be with these S&S g carbs...i cant seem to blip the throttle fast without a hesitation...ive tried to adjust as s&s instructions and am not improving response. if i just twist throttle fast or as normal on hard acceleration its great, but if i try to blip it fast it hesitates...can this be cleaned up or is this it? got ported heads, big valves, S&S xxx carb...33int.78 main, .060 air bleed, .037 int air bleed and one thunder jet...adj thunderheart on setting #3, a 2 into1 S&S air system, and very short FSD exhaust ( which may be part of problem tuning)...PDM wiring...carb runs best at 1 turn open on air bleed, 3\4 and it starts to stumble, 2 turns and starts to stumble....and 2 turns on acc. pump...soooo.
