Hot or not hot?
ricklg2
Shortly after buying my 03 Mastiff I heard rumors about Big Dog engines being notorious for getting hot and/or over heating. Is there any truth to this rumor? If it's true are there any suggestions or special secrets you experienced Big Dog owners have that could help me make sure my Big Dog doesn't over heat?
Loafington
Air cooled internal combustion engines...are hot. My take on too hot would be a ridiculous amount of pinging and shit coming from the engine, (maybe from shitty gas) and the powder coat burning away from areas around where the motor mounts to the frame. I think what you heard is a whole bunch of malarkey. If your ignition was too advanced, it could run hot. Without a temperature gauge on your engine telling you what your head temp is, how would one know? If you are really concerned about excessive heat, run synthetic oil in your engine and an oil cooler. You should try to maintain an oil temp between 180 and 230.
If you do a lot of sitting in traffic on a hot ass day, yeah, your engine is going to get hot. If your engine is running lean, yeah, it will run hotter than one that is running with the correct ratio. But to make a blanket statement that “Big Dog engines run hot”, some one is feeding you bullshit.... Tell them your full.
dogvet
Banned
Notice the big ass cooling fins on the heads and cylinders compared to a 107 or a stock H-D evo engine. It's not that the engine runs hot, it dissipates heat more effectively....therefore, you feel more heat when sitting or putting around. Combustion temperatures are in the 1500 degree range when the engine is under a load and it has to go somewhere. Get those big ass engines on the highway so the heat has somewhere to go!
