outdoorsman26
hl2t lifters.... how do you know if you have them?? talked to s&s and they said i did??? all I told him was that I had a 07 BD Mastiff:loony:
Tim, did your manual have instructions for adjusting the rods with limiters? my 05 manual only has the instructions for without.My 05 did come with them!
Did you ever go back in to make sure you had the .640 springs that I talked with you about? Also did you check to make sure you had the correct spring height for the .600 cam? Just because some guys on here told you the red mark on the spring is the correct spring does not mean it is. It needs 3 springs, not 2. BDM and S&S did not put the high lift .640 springs into that motor. It is an EPA motor with just 2 springs able to go to .585 lift max. Even so, anytime you change cams you want to check your spring height to match the cam being used. Sounds like the S&S tech is not wanting to talk with you because it is a Bigdog. They did not use that style lifter in that motor unless someone has been into that bike already..???Yeah, I have been told bout 4 different ways to set my lifters and I am starting to get nervous that I did it wrong!!!:angry::angry::bang::bang:
I set them by taking the front cyl to tdcc adjusting intake to zero lash plus 4 turns, and waitng for it to bleed down then the exhaust the same way, and then to the rear cyl.. tdcc intake.......... anyway I keep getting this feeling I fucked it up!!!!!
And I dont know what they are the S&S tech said I had them and I have to set my lifters differently!!!
Marv, I go to zero lash (wait about 10 Min) check lash again (no drag) and then just loose enough to spin with slight drag. But instead of trying to get to TDC on the right cycle. I use a dial indicator and put it on one of the lifter and turn it until it is at full travel, then I adjust the opposing cylinder same valve.Tim, did your manual have instructions for adjusting the rods with limiters? my 05 manual only has the instructions for without.
i installed limiters in mine and the adjustment is different.
TDC
bottom out the lifter (after bleed down it doesnt spin)
go to zero lash
1 full turn looser
i hear you.Marv, I go to zero lash (wait about 10 Min) check lash again (no drag) and then just loose enough to spin with slight drag. But instead of trying to get to TDC on the right cycle. I use a dial indicator and put it on one of the lifter and turn it until it is at full travel, then I adjust the opposing cylinder same valve.
I do tend to go with the 3 flats or about 1/2 turn looser also.
Not about being mad, it's about BDM having built your motor to their (EPA) specs not S&S so they really can't comment on what might be in your motor.why being a big dog owner makes s&s techs mad we keep them in business????
i hear you.
starting the adjustment with the tappet piston bottomed out by using pressure from the valve, i guess the term 'zero lash' isnt correct.
like J Sachs said, getting to the point where you can 'just spin the rod' means the valve spring pressure is off and your ready to adjust.
if i recall:
tappet piston travel = .20
hlt2 size = .10
1 full turn = .05 (center of travel?)
1/2 turn = .025 (solid lifter baby!)
wasnt long ago we traveled this road
http://www.bigdogbiker.com/forums/technical/8172-tappets.html
TDC of the comp stroke both valves are closed.If you look at the cam profile top dead center has the valve still open slightly
loaded up on the toro's from x-mas but i'm missing the Bush!Still have the Black Bush and Cohiba to share with you, regardless of the outcome.
Well let see what I can do, maybe the weather will be decent for next weekend or the one after and I will make a little road trip up your way. Or maybe Monday if it is not bad, are you working Monday?loaded up on the toro's from x-mas but i'm missing the Bush!![]()
