It shouldn't be that hard. I would pull the clutch rod assembly apart and grease everything and lube your clutch cable.2005 Mastiff hard clutch. Were they always that bad? Or is something wrong? It seems Awfully smooth to be dirty just need huge forearm. Local Harley shop said not right but won’t touch it and gave no advice.
You are extremely unlucky. Marky-Marc had a lot of great videos on big dogs. He had one on the clutch rod assembly. Unfortunately, he just left the site and pulled all of his videos down. I'm off work because of the virus, paid fortunately. If no one jumps in and explains, I'll try to do a write-up tomorrow. It will give me something to do.Any good vids on pulling all that?
omg you're right - no longer a section on this site and no longer any videos on youtube, such a valuable resource ... what happened?You are extremely unlucky. Marky-Marc had a lot of great videos on big dogs. He had one on the clutch rod assembly. Unfortunately, he just left the site and pulled all of his videos down.
Not sure if this will fix your problem but thought I would share....2005 Mastiff hard clutch. Were they always that bad? Or is something wrong? It seems Awfully smooth to be dirty just need huge forearm. Local Harley shop said not right but won’t touch it and gave no advice.
Give me a call and I'll walk you through it2005 Mastiff hard clutch. Were they always that bad? Or is something wrong? It seems Awfully smooth to be dirty just need huge forearm. Local Harley shop said not right but won’t touch it and gave no advice.
He is moving and changing jobs. I'm not sure why that required removing all of his stuff. I don't know Marky personally, but he has helped me immensely with his knowledge. I understand that it is his intellectual property, and he can do with it as he sees fit, but a loss of knowledge on any subject is very sad. JMHO.omg you're right - no longer a section on this site and no longer any videos on youtube, such a valuable resource ... what happened?
The link is in Mr. Wright's signature block..... 3 posts above....Good. I'm sure Mr. Wright can do a better job of explaining things than I can. Can someone guide him to the service manuals area? That would be a good thing for him to have.
It's two different clutch cable systems. What Mark showed you with them easy pull parts, we're going to go over on how to put them in and get it adjusted properly with a 12 disc clutchLittle frustrating when I can walk over to the Wolf and squeeze it off with one finger and then go back to the mastiff and I have to use the whole hand
Remember, the wolf has the easy pull ball and ramp. It does make a noticeable difference.Little frustrating when I can walk over to the Wolf and squeeze it off with one finger and then go back to the mastiff and I have to use the whole hand
