Thanks for the info. I don't have a service manual.I have a 2008 big dog and it seems like the left fork tube is backing out from the top tree has any one had this problem and if so what is my fix
Yes the bike should be in the air (Weight off the forks)Thanks for the info. I don't have a service manual.
Should the bike be raised with no weight on it or can it be done on the ground?
Also, is the top of the fork tube threaded or does it just slide in?
Do I need to loosen the bolt on the top of the triple tree?
