help with starter bearings
My starter had to much oil to save the copper inside so I am ordering armature from wild steed. It does not show the bearing with it and I need to put new ones on. the bearing numbers are KML 6200 z and KML 608 z. I've looked online and cant find them anywhere. Any info would be helpful, wild steed do you have these at your store I'm ordering a armature, brush holder and coil field I just need the bearings. thanks
Hey Totall
Just put a note on the invoice to WSW that you need the bearings with the armature and I will make sure they get put on it before it ships....:D:cheers:
