HELP WITH PDM HORN RELAY KIT INSYALL
07bigdog
07BIGDOG
Have one of the early PDM kits installed in a 2007 K9. There are 2 wires that have to hook up to the HCI from the horn relay kit. You remove one gray wire from position 3 and install the long wire from the horn relay kit in that spot. There is a short wire from the horn relay that has to be inserted into position 1.. There already is a wire installed in that spot. Thought maybe it had to be installed in position 1 of the other plug in end. Wrong whole system is dead. Installed original horn relay and everything is the same as before. When the bike is running and you press the horn, the bike shuts down. The instructions I have are not clear where the other wire plugs into. Has anyone got some better instructions for installing this horn relay kit with the PDM harness? Help.
