I don't think your bike has a cam sensor, it has a crank position senor on the left front of the mike right by where the stator plug is located. It has two wire that run all the way back to the ignition module. Go to the how to section and test it see if its working and if it is not I'll send you one, just PM me your address..
CRANK SENSOR TEST
Disconnect the plug wires and unplug the
crank sensor. Set the DMM to measure AC
volts and measure across both pins of the
plug. While cranking the engine, you should
see AC voltage greater than 1 Volt. If no
voltage registers, replace the crank sensor.
Carlos
