Help,please..electrical!
Sanchess
Hello! there such a thing ... I've got a chopper 03, brought to the garage, he began to understand what and how ..sat down on the seat and began to buzz itself beep. stop signals do not workeverything as if working, I envy a little traveling.read the topics on the forum regarding these issues, took dielectric grease lamp, meter well and went to see.
I'll tell you that the former owner did not really care about a motorcycle. all in oil, wear, corrosion,wire with a pressure sensor on the foot brakes were torn and covered with sanitary silicone technical! ... okay
on tap found worn-insulated wire, the wire was visually in the EHC and other compounds sprinkled electro grease,put a new battery..
still stop signals do not work, and yet now gone and turn signals!
What to do?
spent a week in the garage...
Nukeranger
Nukeranger
I believe all you need is an electrical Schematic for the 2003! The translation has made it hard to understand your problem. Is your problem only the turn signals and brake lights?
Wills67
Also sounds like the bottom of the seat is touching the battery terminals when you sit down. Make sure the battery is the right size and put something between the seat pan and the battery.
Nukeranger
Nukeranger
Good idea about terminals. I would take them all off, clean them and the battery posts, put them back on and make sure they are tight. Try leaving the seat off and checking out the electrical issues. If they are gone, like said above put an insulating material between the battery posts and connections and the seat. It can be as simple as putting on electrical tape or rubber covers over the terminals.
