help identifying hole?
Kdub
First time posting a PIC. I hope it works. Does anyone know what this little hole is that is full of silicone?
My first thought was...this post should be in the alley!!!
IMG_20140617_212634_986_zps0d8e242b.jpg Photo by kdub26 | Photobucket
Here is another approach. When I see my address line past the JPG, I want to use URL, if past the jpg. I need to find that address that ends in jpg.
[bracket IMG]http://i1370.photobucket.com/albums/ag242/kdub26/Mobile%20Uploads/IMG_20140617_212634_986_zps0d8e242b.jpg[see the JPG end in the address?]
That's the photo image is when JPG stops at the end. Then grab that address line. Meaning, find any photo on the net, click on the drill down so it shows the photo image, then look at the end of the address so jpg ends by itself.
Someone will come along and answer what is what you are looking at.
francoblay1
The Spaniard
That hole holds an Allen screw which holds the Stator plug in place.
It should NOT be full of silicone... there should be the Allen screw!!!!
Brew
Ah yes it should have silicone in it. The silicone traps the oil from coming past the stator plug and the set screw. Both my scoots have it there and I put it back when I did my 3 phase system install.
francoblay1
The Spaniard
Yes in the inside.... not in the little hole where the Allen screw should be! My guess then is that somebody forgot to place back the Allen screw and the silicone made its way out through there?
