migai082681
Need to know what size starter is on the factory 08 Ridgeback. What brand is good. Any ideas
That tell me you need a new battery. If the starter was bad it would not spin your motor at all. I would get a New Battery it takes one with hugh balls to turn this motors. Harley sells the AGM that has 310 CCA for about 100 bucks. Don't buy a battery with less than 310 CCA. Lot of riders on here use that batteryI think it the starter when i crank it it struggles to turn over the motor. When i take the plugs the motor spins freely
Why? They are electronic and work automaticallyI got a brand new brille battery, and as for the compression releases have to press manualy
That doesn't mean the Battery is good you should have it test loaded and see what its putting out. if It is less than 12.V it will not start your bike. FYI I have gone through 1 BDM battery, 1 Big Boar and 2 Braille in the last 6 years so. The best I have found this far is the TR-B1550 with 465 CCA.I got a brand new brille battery, and as for the compression releases have to press manualy
